[Solved] Applink Bug
haikalle
  • Applink Developer
Hi!
I think that there is a small bug with applink code.
If you want to use 3DC -> Other 3D app . You press File -> Export to -> choose your 3d app. Then it will open window where to save you file. It only gives obj type to choose. After
that window it will open export window. There is Output Mesh option and it will give more options (fbx, dae etc...) if I choose dae file and press export. It will save it as dae file but
in applink export.txt it reads 'Object.dae.obj'
Solution idea: Could we add all export types into first window and then it copys data to seconds windows "Output Mesh" box
Edited by haikalle
  • 3 weeks later...
  • Carlosan changed the title to [Solved] Applink Bug
