Contributor Rygaard Posted July 3, 2018 Contributor Share Posted July 3, 2018 Hi! Hey everyone... Could someone please confirm a possible error? My version of 3D-Coat is 4.8.18 and I tested it with the GL and DX. I'm trying to use the Curve Stroke in the Sculpt Room in conjunction with any brush (freeze, Clay or others brushes) and it's not working. The percentage of the calculation appears when the tool is applied and as a result nothing happens. Now, when I went to the Paint Room, I chose the Stroke Curve and it worked correctly. I did the same test on the previous version of 3D-Coat 4.7 and the Stroke Curve worked perfectly on the Sculpt Room and Paint Room. Does Curve Stroke in the latest version of 3D-Coat not working in Sculpt Room? Thank you for your attention. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/ Share on other sites More sharing options...
Carlosan Posted July 3, 2018 Share Posted July 3, 2018 Cant replicate sorry, did you try using other tools with different depth ? You could try the new curves editing tool by using the option Brush Along Curve. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154058 Share on other sites More sharing options...
Contributor Rygaard Posted July 3, 2018 Author Contributor Share Posted July 3, 2018 - In 3D-Coat 4.7, it works perfectly. - I can not run Curve Stroke normally on 3D-Coat 4.8.18. (Only works with new beta curves enabled.) I have tested it several times and with various types of settings and it does not work. The calculation percentage appears, but with no effect of the brush with open or closed curve stroke. I tried different values on Depth with all the sculpture brush and with the Brush Freeze... nothing worked for me. Honestly, I do not know what's going on with the normal mode of Curve Stroke in 3D-Coat 4.8.18. Remembering again that for me it works only when I activate the option in the preferences of the new Beta Curves, but if I do not use new Beta Curves does not work. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154077 Share on other sites More sharing options...
Contributor Rygaard Posted July 3, 2018 Author Contributor Share Posted July 3, 2018 @Carlosan I do not know what's going on ... I've always used Stroke Curves and this kind of mistake has never happened to me. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154078 Share on other sites More sharing options...
Carlosan Posted July 3, 2018 Share Posted July 3, 2018 hmmmm... Try deleting C:\Users\user\Documents\3D-CoatV48\Options.xml Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154080 Share on other sites More sharing options...
Contributor Rygaard Posted July 3, 2018 Author Contributor Share Posted July 3, 2018 2 hours ago, Carlosan said: hmmmm... Try deleting C:\Users\user\Documents\3D-CoatV48\Options.xml Thank you for trying to help me ....Unfortunately, I did not succeed.I followed your suggestion exactly by erasing the file, I restarted the program, but I continue with the Curve Stroke problem I described.Really very strange, it's as if the functionality of the curve did not exist. The percentage of functionality is displayed and nothing happens as a result.I do not know what to do... Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154082 Share on other sites More sharing options...
Contributor Rygaard Posted July 3, 2018 Author Contributor Share Posted July 3, 2018 Is there any property that could interfere with Curve Stroke?I already checked the depth. It is beyond 50.I checked if the Steady Stroke option is enabled. And it is not!I have already checked the properties of the brushes and the alpha to be used ... and everything is normal.Is there anything else I can be forgetting? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154083 Share on other sites More sharing options...
Carlosan Posted July 4, 2018 Share Posted July 4, 2018 Stroke depth limit, brush options, alphas, curves... any parameter can be a variable. Do you have another computer to test fresh install ? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154087 Share on other sites More sharing options...
Contributor Rygaard Posted July 4, 2018 Author Contributor Share Posted July 4, 2018 36 minutes ago, Carlosan said: Stroke depth limit, brush options, alphas, curves... any parameter can be a variable. Do you have another computer to test fresh install ? Unfortunately, I do not have another computer to do this test.But in the previous version of 3D-Coat 4.7 (it's installed on this same computer) is working properly with the Curve Stroke.I have seen all these parameters and everything is normal.Nothing that these variables influence the Curve Stroke in the Sculpt Room ...I just did a test:I did a Curve Stroke in the Sculpt Room and it did not work. Then I switched to Paint Room to reuse the same curve I did in the Sculpt Room using paint and it worked normally in the Paint Room.Something in the Sculpt Room is happening to me, making it impossible for Curve Stroke to work properly in the Sculpt Room. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154088 Share on other sites More sharing options...
Contributor Rygaard Posted July 4, 2018 Author Contributor Share Posted July 4, 2018 I do not know if I would open another topic to report other problems in 3D-Coat 4.8.18 that is happening to me - especially in Sculpt Room's Surface Mode.I'm having problems with the Clone Tool and Cut & Clone tool when they are used in the SURFACE mode of the sculpt room.The problem for both tools is the same.When I select a certain part of the mesh (using any type of Stroke Modes), the tool calculates and as a result the cloned part that I chose appears, but all the previous mesh is deleted. Only the part chosen by me is left on the screen and mysteriously all the mesh I made the operation disappears. Remember that this only happens in Sculpt room - Surface mode.In Voxels mode, the tools work correctly. The tool clones, but leaves the mesh that has suffered the operation intact.I have already uninstalled the program and installed earlier versions of 3D-Coat and this Clone tool and Clone & Cut tool error still happens. In the 3D-Coat version 4.8.08 the Clone tool and Clone & Cut tool work correctly in Surface mode. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154089 Share on other sites More sharing options...
Carlosan Posted July 4, 2018 Share Posted July 4, 2018 Cut & Clone tool Bug confirmed and reported Thx 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154091 Share on other sites More sharing options...
Contributor Rygaard Posted July 4, 2018 Author Contributor Share Posted July 4, 2018 7 hours ago, Carlosan said: Cut & Clone tool Bug confirmed and reported Thx Thanks for confirming the bug in the tools:- Clone Tool- Cut & Clone toolI was already thinking that these mistakes were just happening to me.-----------------------Returning to the subject of the topic, about the functioning of the Curve Stroke in the Sculpt Room. Are you sure that Curve Stroke has no bug?When I installed earlier versions of 3D-Coat, Curve Stroke also did not work in Sculpt Room. In the 3D-Coat version 4.7 is working correctly.What I can confirm for you in 3D-Coat 4.8.18 is that when I activate the new Curve Beta preferences, the functionalities of the curves work.The only thing I do not understand is that when I use the Curve Stroke and hit the enter key, nothing happens ... I have to go to the curves menu and choose the Run Brush Along Projection option to work as I was accustomed to use the same tool (default Curves of the program) by pressing the Enter key.However, I would not like to use the new Beta Curves because it is still in the development stage and has many bugs (of course this is normal for a tool being developed!).So I'd like to use the program's Standard Curves ... but unfortunately, I've done several tests and looking closely at all the properties that could influence the Curves Stroke and I did not see anything wrong.I can only think that it can be a bug... Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154116 Share on other sites More sharing options...
Carlosan Posted July 4, 2018 Share Posted July 4, 2018 When I use the Curve Stroke and hit the enter key, tool is working fine. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154118 Share on other sites More sharing options...
Contributor Rygaard Posted July 4, 2018 Author Contributor Share Posted July 4, 2018 39 minutes ago, Carlosan said: When I use the Curve Stroke and hit the enter key, tool is working fine. Thank you for your attention and for trying to help me.Can you tell me if Andrew will release a version 4.8.19 before launching the version of 3D-Coat that implements Sculpt layers?If we have this version 4.8.19 with bugs fixed, maybe I have some hope that Stroke Curves might work on my computer when I install this version.I've already given up hope of running Curves Stroke on my computer with the version of 3D-Coat 4.8.18 ... I've tried everything and it did not work with anything I've tried. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154119 Share on other sites More sharing options...
Carlosan Posted July 4, 2018 Share Posted July 4, 2018 I dont have access to development agenda, sorry. Please send him an e-mail and ask. Thx. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/22517-solved-using-curve-stroke-in-sculpt-room-3d-coat-4818-does-not-work/#findComment-154122 Share on other sites More sharing options...
