3D coat 4.8.18 and empty fbx file..??
marou_666
Hello
I have a problem with latest 3d coat version which is 4.8.18,
when I use export scene or export selected objects in *.fbx format, it exports just fine, but file itself is 0kB... every time, tried diferent files, same thing, tried reinstalling coat, same thing, exporting *.obj files works just fine though....
this is a HUGE headache for me, and I am not a noob so I am sure I am doing everything correctly , since I exported this way many times before..... unless there is some new "feature" that I am not aware about.. :O
anyways, I would greatly appreciate any help with this.... also wonder if anyone else have same issue..??
aside from that, love the software, keep ut great work devs
cheers
I usually dont even use this reduction with exporting, I reduce mesh manually, hovewer..... can this actually affect exported file..?? It never happed to me before, I usually set reduction percent as 0 value and file allways come up ok
I can upload a FBX file if that helps....
