3D Coat Forums
polvda
Delete, remove object. Help file/webpage?
Using 3DCPrinting, trial version.
How to delete an object?
I read the only way is via layers. So when you forget to add a new layer and by mistake add a new unwanted object, chances are you have to start all over again. Correct me if I'm wrong
Is there an option to "Auto create layer" when adding an object?
Why is such a simple task (delete object) so complicated and burried?
Why is there an item "Delete" in de right click menu?"
Is there a help file/webpage? I'm tired of watching YouTube and searching the forum for hours just to search for one item.
So far I doubt seriously about buying the program.
Greetings,
Pol
Hello
Select the option Import As Child.
How to delete an object ?
Clear current object delete the objet but keep the layer empty
Open Voxtree properties by pressing RMB over the object and select the option delete.
When you forget to add a new layer and by mistake add a new unwanted object, chances are you have to start all over again. Correct me if I'm wrong
If you are working on Surface Mode use the command Geometry > Object-ify to separate the components to new layers.
Hope this help.
