blade33ru
retopo problem
i modelled  apair of pants for character.  export as autoretopo and reimport to sculpt to  add cloth dynamics.  excellent. reimport as high res voxels.  pants now look natural and wrinkled.
BUT.  after this process, if i want to re auto retopo it builds an inner and outer shell.  any way to limit that to outer shell only.  if not is there a shell selection mode in retopo room so i dont have to waste my day tracking down stray polys
also using the retopo brush often snaps to interior shell even if i have ignore backfaces turned on.  strokes create inner and outer stroked for inner and outer faces.  seems like a major workflow bottleneck
Edited by blade33ru
If you are going to autopo again, fill the pants with a solid version. In voxel mode merge them and autopo. It uses fewer polygons.B)
yeah but obviously the  solid version doesnt fit really since i did the cloth sim so not a great solution.    the whole idea of the cloth sim is to make cool clothes.  we should be able to retopo them simply .  pretty difficult ..and painfully slow... with auto or manual.
  the only way to make shell selections that i can see is to create temporary UVs then select the polys based on UVs.  ok workflow i guess.
Edited by blade33ru
... reimport as high res voxels. ...BUT.  after this process, if i want to re auto retopo it builds an inner and outer shell.
Mesh is closed ?
... any way to limit that to outer shell only.
duplicate, decimate, close holes, retopo. Delete not needed faces before unwrap
got both retopoed now.  was a pain in the ass...u can see i have interior and exterior surfaces .  both get retopeod.  strokes tool suck in this case.  creates strokes inside and outside.  autoretopo creats interio and exterior.  maybe a raycast option would be good...this method of modelling -retopo to sculpt- is very useful especially for vehicles and obviously for cloth
later in maya after arduos polygon deleting process
i ended up doing autoretopo in zbrush cause dear old 3dcoat was soo slow with this.  1 minute in z brush...got those crappy spirals but whatever
could you try the solution I suggested ?
duplicate the model
decimate the model
close the holes and make it only one external surface
retopo that new decimate model with holes closed.
Delete not needed faces added when close the model holes before unwrap
i will try . i had doen this work before i read you post...altho...not sure....those holes might not register as holes because they ar eintact surfaces in surface mode not errors.  but willl try
yeah the trick is 'make it one external surface'.  there is NO easy way to do this other than delete lots of polygons.  actually the easiest way is to do auto retopo ..make UV edge seams, select the interior uvs, convert to faces and delete the import the surface into voxels in surface mode and use the close holes tool.  thats a lot of work,  creativity killer
if the cut off tool had an option to not cap the polys that might be useful with a shell selection.  actually pose tool has an object mode which is like shell selection so thats done
Edited by blade33ru
ok update.  the remove polygons tool.  alows separation of interior and interior polys in surface mode but pose object mode selects both sides.  bummer
sucess  lol...amazing.  had to import from retopo, then use close hole tool then convert to voxels. BOOM
Edited by blade33ru
