Member GrzegorzWięcek Posted July 26, 2018 Member Report Share Posted July 26, 2018 Hello guys, Each time I open my UV room, "Apply UV set" command is mark yellow, no matter what I do, all the time (look attached screen print). How can I solve this issue? Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 26, 2018 Author Member Report Share Posted July 26, 2018 and then when I come back to paint room after apply, the preview object become very noisy ;/ Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 27, 2018 Report Share Posted July 27, 2018 Paint room > View > Show Voxels in Paint Room is switched off ? Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 Show Voxels in Paint Room is enabled (turned ON)... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 27, 2018 Report Share Posted July 27, 2018 Turn off please Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 no difference, after disable ;/ In render room there are some issues after I apply UV set in UV room. I think there is something wrong with my UV room, each time a make some changes and apply UV set it becomes noisy, and issues in Render room appears ;/ Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 (edited) I consider reinstalling 3D Coat... do you think it is good idea? I'm working on iMac I thought maybe that there is something wrong with drivers, or graphic card, but my iMac is new, and I thing that the parameters are sufficient to work in 3D Coat... Edited July 27, 2018 by GrzegorzWięcek Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 Sorry, I've notice something, right now, that when I disable 'Show Voxels in Paint Room' BEFORE, at the beginning of my work, everything works fine, and my preview looks fine, I guess thats the solution does it means that each time I start working in Paint room I have to turn off 'Show Voxels in Paint Room' option?? Thanks What about this yellow marked 'Apply UV set' command is it default in version 4.18.16A? maybe it is normal... PS. by the way, great support you supply to 3D Coat users here on forum. Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 ;/ sorry it is still there, the issue Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 27, 2018 Author Member Report Share Posted July 27, 2018 It seems like it's all right at the moment, I will see, how it will goes, thanks 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 27, 2018 Report Share Posted July 27, 2018 I start working in Paint room I have to turn off 'Show Voxels in Paint Room' option... You can use Paint room to... paint textures (UV based) or Polypaint (vertex based) If you switch from sculpt room to paint room for Polypaint, let Show voxels... on. If you switch from sculpt room to paint room for UVpaint, let Show voxels... off. At retopo stage you can see the option Bake AO, dont use that command, switch it off. Its deprecated. Better to use Paint Room > Textures > Calculate Occlusion with option Separate paint objects = on 1 Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 30, 2018 Author Member Report Share Posted July 30, 2018 Thanks, thanks 1 Quote Link to comment Share on other sites More sharing options...
