Member Erza86 Posted August 13, 2018 Member Report Share Posted August 13, 2018 Hi, 3D Coat i have question about sculpting, when i use some brush like smooth, grow, or build. The brush function just jump over the other layer (just like the image), when i work on the layer number 1 (the ant head) and begin sculpt at the edge of the mesh and very close with the second layer ( the ant eye), the second layer just flashing and get sculpted, is there a way to lock the other/second layer? so i can work the first layer without touching the second layer and both layer are visible. and masking function not appear in voxel only in surface Thank You Quote Link to comment Share on other sites More sharing options...
Advanced Member Falconius Posted August 13, 2018 Advanced Member Report Share Posted August 13, 2018 YOu can ghost the layer you don't want to touch, but it's not really a solution. More importantly you can turn off 'auto pick' at the top bar there and then it won't automatically switch to the layer where the mouse is. 1 Quote Link to comment Share on other sites More sharing options...
