Member Przemas Posted August 17, 2018 Member Report Share Posted August 17, 2018 I'm trying to use window (rectangle) selection with surface hide. The problem I have with it is that only front facing items get hidden - I'd like to include backfaces as well. Is it possible? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 17, 2018 Report Share Posted August 17, 2018 Hi Try this command Quote Link to comment Share on other sites More sharing options...
Member Przemas Posted August 23, 2018 Author Member Report Share Posted August 23, 2018 thank you Carlosan, that's it . I'm struggling with one bug though - in both voxel and surface mode sometimes unhidden part of the object is getting damaged (sort of like surface has been offset a tad) . It does not happen every time - but makes me super careful when dealing with the vox/srf hide. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 23, 2018 Report Share Posted August 23, 2018 Yes, bug regression confirmed and reported Quote Link to comment Share on other sites More sharing options...
Member Przemas Posted August 24, 2018 Author Member Report Share Posted August 24, 2018 is there a known back version without this regression? Tried 4.8.18 and I'm getting the same problem. It can be workaround by duplicating the layer (duplicated layer work for a time, then you need to duplicate them again), but I'll gladly fall back. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 25, 2018 Report Share Posted August 25, 2018 Please contact support@3dcoat.com for any back version. Quote Link to comment Share on other sites More sharing options...
