Member DavideBianchini Posted September 2, 2018 Member Share Posted September 2, 2018 (edited) Hey guys, I'm sure this has been asked before, but I was curious if there is a button that will auto-fit the UV islands to completely fill the UV tile/preview window. I have attached an image below of an example I am working on now. Pressing "auto-scale" didn't seem to do much. Thanks! -Davide Foundation_Walls_Bottom.3b Edited September 2, 2018 by DavideBianchini Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted September 2, 2018 Contributor Share Posted September 2, 2018 It may be choking on a serious over supply of polygons. I suppose you've tried PackUV2? Just guessing but you might get rid of some geometry that's really not needed. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 2, 2018 Share Posted September 2, 2018 You cant fill the UV tile/preview window with that UVlayout. You need good pixel density to avoid backing issues. On your unwrap, islands are not proportional. Try adding more seams on large islands and unwarp again to see the changes . Quote Link to comment Share on other sites More sharing options...
