Talik 2 Report post Posted September 11, 2018 Hello I'm having a bug. When filling a layer with material normals are maximum intensed. When filling object with material everithing is fine. Bug appears when filling layer only. Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 11, 2018 Please check normal value on fill tool. are ok ? Share this post Link to post Share on other sites
Talik 2 Report post Posted September 12, 2018 Checked are ok. When click on object is works properly. Bug appears when clicking on fill layer/material/object. It's the same tool. Share this post Link to post Share on other sites
Talik 2 Report post Posted September 12, 2018 (edited) Edited September 12, 2018 by Talik Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 12, 2018 Please test latest version 4.8.22 Share this post Link to post Share on other sites
Talik 2 Report post Posted September 12, 2018 Just have tested. Same bug Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 13, 2018 And with this version, do you have same bug ? http://pilgway.com/files/3dcoat/V4.8/3d-Coat-V4_8-23-64.exe Share this post Link to post Share on other sites
Talik 2 Report post Posted September 13, 2018 Yep. Same bug Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 13, 2018 This is the same object filled using Layer (left), Surface (center) and Object (right) No differences. 1 Share this post Link to post Share on other sites
Carlosan 2,463 Report post Posted September 13, 2018 //edit Solved on latest version ----------------------------------------- Clicking fill tool over same object, the result of the normals mapping is lower. I am reporting bug. Thx 1 Share this post Link to post Share on other sites
Talik 2 Report post Posted September 13, 2018 Thanks for quick reply. Waiting for good news Share this post Link to post Share on other sites
druh0o 52 Report post Posted September 13, 2018 (edited) I'm not sure if that's the same issue, but there is a difference between filling with the Fill Tool and Fill Whole Layer via right mouse button on a layer. Edited September 13, 2018 by druh0o 1 Share this post Link to post Share on other sites
Talik 2 Report post Posted September 13, 2018 1 hour ago, druh0o said: I'm not sure if that's the same issue, but there is a difference between filling with the Fill Tool and Fill Whole Layer via right mouse button on a layer. Haha this works)) Thanks a lot you've saved a lot of time for me. I can keep working on my projects)) Share this post Link to post Share on other sites
Talik 2 Report post Posted September 23, 2018 On 9/13/2018 at 1:23 PM, Carlosan said: Clicking fill tool over same object, the result of the normals mapping is lower. According to the name of topic I just want to remind that bug is not when using LMB. Bug is that normals are higher when using Layer/Surface/Object button. It's easily can be checked cos clicking LMB gives the same result as in preview window Share this post Link to post Share on other sites
