haikalle
[BUG] Brush engine issue
Hi!
I downloaded this video for you and I hope you can help about this issue. Is that a bug or not.  If I keep mouse button down and create a stroke where in the end it goes from surface into empty space it creates a bump. I checked all other sculpting programs and they seams to work differently.  In Voxel mode it works very good but not in surface mode.
Try Geometry > Stroke expansion = off
I did quick test with most tools in 3d-coat. I would say that ok behaviour tools are: Draw, Expand, Extrude, Gum, Absolute. rest tools has some issues I think.
Same behavior in ZB with buildup brush.
@haikalle
An interesting fact is that all your "problematic" surface tools (except buildup tool) have this buildup option (in options bar).
Although not enabled it builds up a bit at the end.
Edited by The_Mikeman
Bug confirmed.
4.8.34
There is a setting in zbrush to fix this. We found it under Brush/Samples/Preserve Edge.  Set that to 100 % and the problem goes away.
Even Blender gets this right.
Pity that 3d-Coat does not have this function, as I will be working on film quality animals soon, and this bugged me sooo much the previous round.
Edited by Werner_Z
