Member Makketronics Posted September 15, 2018 Member Report Share Posted September 15, 2018 I have 2 layers. The one I am working on is slightly inside the other one. I am trying to do re-topology manually on it. However, when I reach the side which is buried inside, my quads, points, or any other thing, such as pushing F to rotate round, keeps snapping on the outside layer, although it is hidden. I am unable to complete my retopology, and I am not sure how to make the points ignore the hidden layer. In other words, the hidden layer is blocking the visible layer, and it is not really hidden to the computer, and only hidden to the human. Any ideas? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 15, 2018 Report Share Posted September 15, 2018 Are you using latest version 4.8.23 ? Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted September 16, 2018 Contributor Report Share Posted September 16, 2018 Turn off Auto-snap and move your points. when done, select the points and use the Snap to the points using one of the choices in the snapping drop down, If you're satisfied, turn Auto Snap back on. Quote Link to comment Share on other sites More sharing options...
Member Makketronics Posted September 16, 2018 Author Member Report Share Posted September 16, 2018 Thank you. That helped. Regarding the version, I am using 4.8.20. If I check for updates, it tells me I have the latest software. Is 4.8.23 actually released, or beta? Quote Link to comment Share on other sites More sharing options...
Member Makketronics Posted September 16, 2018 Author Member Report Share Posted September 16, 2018 I just confirmed that hidden objects still block actions in 4.8.23SL. Maybe it is the intended behavior, but it would be nice if we could simply work on a different layer without having interference with hidden layer. Note: If you are trying to replicate this, for the first layer, I do have it baked, retopoed, and in the paint room, hidden. Quote Link to comment Share on other sites More sharing options...
