[Fixed] selection tool bugs if any floating panel is open
I've ran into a weird bug with the selection tool.  It seems as soon as I invoke symmetry, the lasso and polygonal lasso selection tools don't work (see the attached video). I'm pressing the mouse button, but no green line shows up.
I've tested this with .23, .22, and .20....this issue does not exist for me in .20 so for now I've downgraded.  I've also tried re-installing .23 but the issue is still there.
Edited by nobackup
  • 3 months later...
just to follow up on this...
- This issue still persists in .32
- deleting options.xml solves it, but it re-occurs after some time while modeling.
- EDIT -> RESET SETTINGS also solves it, but again it pops back up again after a bit.
- It doesn't seem to matter if symmetry is turned on or not.
- It happens most with the Cut Off tool, and also with the Vox Hide tool.  This might just be coincidence though, since I use those tools often.
  • Carlosan changed the title to [Solved] selection tool bugs
  • 1 year later...
  • Carlosan changed the title to [Fixed] selection tool bugs if any floating panel is open
