3D Coat Forums
nobackup
[Solved] selection tool bugs
I've ran into a weird bug with the selection tool.  It seems as soon as I invoke symmetry, the lasso and polygonal lasso selection tools don't work (see the attached video). I'm pressing the mouse button, but no green line shows up.
I've tested this with .23, .22, and .20....this issue does not exist for me in .20 so for now I've downgraded.  I've also tried re-installing .23 but the issue is still there.
Edited by nobackup
I was trying but can replicate it.
Please try deleting all the Options____.xml files located on the folder
C:\Users\username\Documents\3D-CoatV4___versionNumber
(backup all .xml files first)
just to follow up on this...
- This issue still persists in .32
- deleting options.xml solves it, but it re-occurs after some time while modeling.
- EDIT -> RESET SETTINGS also solves it, but again it pops back up again after a bit.
- It doesn't seem to matter if symmetry is turned on or not.
- It happens most with the Cut Off tool, and also with the Vox Hide tool.  This might just be coincidence though, since I use those tools often.
This is probably caused by some "floating" window.
Workaround: Try closing floating windows (or dock them) and the lassos should work again!
Edited by The_Mikeman
hmm..interesting!  I'll try this, thanks!
