3D Coat Forums
MattVG
Animated Checker Pattern After Unifying UV Maps
Hello,
I texture painted a model composed of various objects that all use the same texture. Each object was UV unwrapped (in Blender) and packed such that they all fit next to each other so I can use a single texture. I brought this model into 3D-Coat, textured it, exported the texture, then realized I need to update one of the objects. I updated it, then imported the object into 3D-coat. I'm not sure exactly how to get the updated object to use the same texture all the other objects are using, but unifying the UVs seemed a good shot.  After unifying the UVs, applying the changes, and moving back to the Paint room, every object is now textured by an animated checker pattern.
What am I doing wrong?
Thank you for the help.
No one else has had this issue? I couldn't find any reference to it in the manual and no solution online.
Hi
This video continues the demonstration of 3D Coat's ability to allow the artist to modify the UV's of a model after the fact, without the penalty normally associated with doing so.
//edit
Thank you for posting the video, though it doesn't address my issue.
I have a little robot. I added a name plate to it. I want 3D-Coat to use the same image texture atlas for the name plate that the rest of the robot uses so I don't have to re-texture everything. Instead I receive an animated checker pattern across every part of the robot.
Edited by MattVG
that moving checkered pattern happens to me sometimes and its infuriating! Seems to me it can be fixed in the paint room by going to Freeze/Unfreeze All.
Hopefully we're talking about the same thing.
--shift studio.
