Member Erza86 Posted October 25, 2018 Member Report Share Posted October 25, 2018 (edited) hi 3d coaters i have a question about exporting multiple mesh object, i think after i'v done with my work and export it, it will create multiple obj file but i only had one obj and it seems there is no option to make multiple file, the idea is to export it to zbrush for posing my character ( i don't know how to posing character after bake and paint in 3d coat, btw i'm just an amateur with 3d coat ) and when i open the single obj file in zbrush the result is not as expected, i only had one subtool, all the mesh were merge into one subtool not even different polygroups i can make multiple file by delete all mesh except one that i want to export but that way to troublesome, is there a magic button to export all mesh to different files Sorry and Thank You Edited October 25, 2018 by Erza86 forget something Quote Link to comment Share on other sites More sharing options...
Member Speike-Styles Posted October 26, 2018 Member Report Share Posted October 26, 2018 Zbrush has a friendly FBX importer. You should try that instead. Or.... just Select all of them and then export it in ZB as a obj. Then in ZB under the subtool split it. 1 Quote Link to comment Share on other sites More sharing options...
Member Erza86 Posted October 26, 2018 Author Member Report Share Posted October 26, 2018 thanks, the color polygroups in zbrush looks same, but it is not, i had to split all of them thanks to split by groups tool, but the texture i've been working on 3d coat not showed perfectly in zbrush, i would like to posing the char on 3d coat, but i don't know how to do it after retopo and texturing phase, so i don't have a choice to posing all of them on zbrush but i will try with fbx hopefully all the texture is saved (AO, Diffuse, etc) Quote Link to comment Share on other sites More sharing options...
Featured Comment Carlosan Posted October 26, 2018 Featured Comment Report Share Posted October 26, 2018 Try File > Export > Export Scene 1 Quote Link to comment Share on other sites More sharing options...
Member Erza86 Posted October 26, 2018 Author Member Report Share Posted October 26, 2018 Thanks Carlosan, this will help Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 26, 2018 Report Share Posted October 26, 2018 Quote Link to comment Share on other sites More sharing options...
Member Speike-Styles Posted October 26, 2018 Member Report Share Posted October 26, 2018 Glad U figured it out Quote Link to comment Share on other sites More sharing options...
Posted by Carlosan,
1 reaction
Go to this post
