Member rendaridra Posted October 27, 2018 Member Report Share Posted October 27, 2018 When I save a file in 3b I am able to see the file and open it. When I export the file in any other format, it doesn't show up at all, not for 3d-coat or any other programme. I have uninstalled and reinstalled, reset the settings, and am using v. 4.8.23. I have searched the whole computer in case it saved elsewhere but this is not the case. I am at my wits end as I need to save files in obj and stl formats Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 28, 2018 Report Share Posted October 28, 2018 Can you tell me exactly the steps you do when exporting ? Quote Link to comment Share on other sites More sharing options...
Member rendaridra Posted October 28, 2018 Author Member Report Share Posted October 28, 2018 (edited) file > export > export selected objects Edited October 28, 2018 by rendaridra Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 28, 2018 Report Share Posted October 28, 2018 I can not find any problem using version 4.8.25 Try saving it to > desktop After selecting the export option, do you see this image ? Quote Link to comment Share on other sites More sharing options...
Member rendaridra Posted October 28, 2018 Author Member Report Share Posted October 28, 2018 Yes I get that option...and saving it to the desktop didn't work unfortunately Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 28, 2018 Report Share Posted October 28, 2018 Are you using 4.8.25 ? Quote Link to comment Share on other sites More sharing options...
Member rendaridra Posted October 28, 2018 Author Member Report Share Posted October 28, 2018 Yes I am using 4.8.25 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 28, 2018 Report Share Posted October 28, 2018 Try to backup files Options****xml, then delete. Will it save ? If no, please restore files, try to export. Will it save ? If yes, please send me that files Options***xml at support@3dcoat.com Andrew Quote Link to comment Share on other sites More sharing options...
Member rendaridra Posted October 29, 2018 Author Member Report Share Posted October 29, 2018 th ank you for your help, but after much fiddling and searching I found that it was an actual permissions problem because it works when I open it as an administrator. 1 Quote Link to comment Share on other sites More sharing options...
