3D Coat Forums
Tony Nemo
[Solved] Clone tool problems in Retopo
When I try to consolidate the selected faces in one Retopo Object  they are moved to the desired  volume but when their old volumes (empty?) are deleted,  so are they. To test, select faces in a volume and using the "move selected faces to the current layer" tool and try to delete the old, empty layer.
Are moved that faces to the same UV-set before delete it ?
I thought Retopo Objects were separate UV Maps so yes, Layer "wheels" was the current layer when I used the command.  I was having an issue with applying symmetry and lost all the rings except for the last one. They just disappeared. I;ll try again tomorrow.
Edited by Tony Nemo
