Contributor Tony Nemo Posted November 18, 2018 Contributor Report Share Posted November 18, 2018 When I try to consolidate the selected faces in one Retopo Object they are moved to the desired volume but when their old volumes (empty?) are deleted, so are they. To test, select faces in a volume and using the "move selected faces to the current layer" tool and try to delete the old, empty layer. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 19, 2018 Report Share Posted November 19, 2018 Are moved that faces to the same UV-set before delete it ? Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 19, 2018 Author Contributor Report Share Posted November 19, 2018 (edited) I thought Retopo Objects were separate UV Maps so yes, Layer "wheels" was the current layer when I used the command. I was having an issue with applying symmetry and lost all the rings except for the last one. They just disappeared. I;ll try again tomorrow. Edited November 19, 2018 by Tony Nemo Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 23, 2018 Author Contributor Report Share Posted November 23, 2018 This issue is gone from version .28 1 Quote Link to comment Share on other sites More sharing options...
