Advanced Member micro26 Posted November 20, 2018 Advanced Member Report Share Posted November 20, 2018 Hi all , quick question. When you bake from high to low where is the ao layer ? I remember it was automatic using baking per pixel inside retopo tab right? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted November 20, 2018 Reputable Contributor Report Share Posted November 20, 2018 12 minutes ago, micro26 said: Hi all , quick question. When you bake from high to low where is the ao layer ? I remember it was automatic using baking per pixel inside retopo tab right? Andrew removed that recently. The baking was obsolete, compared to the AO baking in the Paint room. Use the AO baking in the Paint Room, instead. Quote Link to comment Share on other sites More sharing options...
Advanced Member micro26 Posted November 20, 2018 Author Advanced Member Report Share Posted November 20, 2018 Is that as accurate as a raytrace bake ? I m looking at something similar to xnormal . Quote Link to comment Share on other sites More sharing options...
