Textures are saved black
Wasili
  • Applink Developer
I wonder why your object is invisible in last video?
I checked your first video again and it seams that your painting your voxel object in there.
Also I see that you have two objects in "paint objects" Does your object include two meshes?
Edited by haikalle
You have 2 Surface Materials, delete the empty one Default1
If you are using PBR metalness check if are working on the right workflow
View > Metalness is showing that there isnt any map painted
Add metalness to paint over that map
I checked everything you said but still don't know what the matter is and what I have to do. I still have textures saved black. And take a look, for some reason in the texture I can draw and on the model can not http://take.ms/iUlrf
1 hour ago, Carlosan said:
Deselect export constructor shown in picture. You will get a new menu.
Make sure "Store gloss/roughness in Metal alpha is deselected.
This will export all your maps correctly.
Thank you! I removed this tick, now works) And why in texture editor paints and does not paints on the model?
Preview options is included on Brush and fill tool only with the Smart Material.
Use camera projection -noy cube mapping- to see how tiling work.
Remember that all your questions are answered in the manual. Please take a look.
Thanks for the link to the manual but still why does not draw on the model? Here's another record from the screen, here I change different projections http://take.ms/L1h0r
8 minutes ago, Carlosan said:
Try deleting options.xml on ...\user\Documents\3D-CoatV48
If you still keep using version 4.8.03 i can not help anymore, because several bugs was fixed on latest version. Please use it , sorry.
I understand, but I have the latest version does not display materials. I sent you a scene, you said you'd test and tell me why, but I didn't get a response from you.
Извините, но я не могу повторить эту проблему.
Я могу рисовать без каких-либо проблем с вашей моделью.
Что делать, если вы начнете новую сцену, используя любую модель по умолчанию, чтобы протестировать комнату Paint? (Shift + M)
The new model draws without problem  http://take.ms/TJMRv  It seems to be a bug and I would gladly draw in the new version of 3d coat but in the new version I have all objects invisible
