Material panel? Project painting?
kirkl
Hi
Applying decals or images is located in the Paint Tools
Also, Andrew designed the 2D Gizmo to be the best way to manipulate your Stencil or Smart Material overlay
Also, Andrew added an option in EDIT menu > PREFERENCES > VIEWPORT tab > check ALLOW MATERIAL NAVIGATION VIA RMB dragging in viewport, to enable hotkeys to manipulate the stencil or material overlay, in the viewport. By default it is disabled because some like it and many do not. It interferes with some navigation hotkeys, so that is why it is turned off, by default.
With it enabled, here are the hotkey commands -Functions:
RMB (outside the model) = PAN
RMB + CTRL = ROTATE
RMB + SHIFT = ZOOM
  • 2 years later...
