Member randomguy_j Posted December 5, 2018 Member Report Share Posted December 5, 2018 Hello, Im currently using a Huion Kamvas Pro 22. When I first starting using this with 3D Coat, everything worked fine! Well I got a new SSD and reinstalled windows and all of my programs. Now for some reason, my Huion pen only erases by default. Selecting brushes or anything else doesnt do anything. I know the Huion software has a "switch brush" mode which is off, but 3D Coat still defaults to eraser mode on the pen no matter what I do. This is only an issue with 3D Coat. I haven't experienced this in Photoshop, Zbrush, Substance Painter or anything else. I even tested my old Wacom to find out the Wacom works normal. Any help would be appreciated as this is beyond frustrating and has wasted a lot of my time. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
New Member joel0827 Posted December 13, 2018 New Member Report Share Posted December 13, 2018 Hey Randomguy_j, I have a Huion Kamvas GT-191, and I was having the same problem as you. In 3D coat I had no problem sculpting on a Huion Tablet. But when I started texturing it erases all the color information. Don't turn off switch mode (Digital Pen Tab), keep it on, or reset settings to default. Allow administrative permission in the Huion App, and hit apply. In 3dCoat open up a simple sphere scene, and try painting on it. If it's not painting click on the button (switch button) closest to the tip of the pen. It should change, and it'll paint this time. Let me know if that works for you. Best, Joel Quote Link to comment Share on other sites More sharing options...
Member randomguy_j Posted January 9, 2019 Author Member Report Share Posted January 9, 2019 Thank you for the response, Joel! I tried resetting preferences before but it didnt work but just for sh#ts and giggles, I tried it again and now it works. Not sure why its deciding to work as intended now but glad to know Im not the only one who had this problem. Thanks again, man :) Matt Quote Link to comment Share on other sites More sharing options...
New Member NATALIE DRAWS Posted February 24, 2020 New Member Report Share Posted February 24, 2020 On 12/12/2018 at 11:13 PM, joel0827 said: I HAD THE SAME PROBLEM. It was sooooo frustrating, but THIS GUY got the answer right, and I was able to get out of permanent eraser mode. 1. Go to HuionTablet stylus setting- make sure "switch mode" is still on 2. Go into photoshop, or whatever software you're using, hover your stylus OVER the Paint Brush tool and click the lower button ( which is in "switch mode") and the brush will come back. 3. Go back to stylus setting and unblock the "switch brush " to end the problem FOREVER lol Quote Hey Randomguy_j, I have a Huion Kamvas GT-191, and I was having the same problem as you. In 3D coat I had no problem sculpting on a Huion Tablet. But when I started texturing it erases all the color information. Don't turn off switch mode (Digital Pen Tab), keep it on, or reset settings to default. Allow administrative permission in the Huion App, and hit apply. In 3dCoat open up a simple sphere scene, and try painting on it. If it's not painting click on the button (switch button) closest to the tip of the pen. It should change, and it'll paint this time. Let me know if that works for you. Best, Joel Quote Link to comment Share on other sites More sharing options...
