New Member CaseFace5 Posted December 6, 2018 New Member Report Share Posted December 6, 2018 Hello there! been using 3dCoat for a while now and something I havent been able to figure out yet is if there is a way to sort of drag select over a bunch of islands that are stacked so I can move and scale them all at the same time. They are all stacked ontop of each other to help with the texture resolution since it is just a bunch of planks of wood that dont really need dedicated space on the uv map. http://prntscr.com/lrbw9j Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 6, 2018 Report Share Posted December 6, 2018 Hi! You may select with rectangle in UV window. Quote Link to comment Share on other sites More sharing options...
New Member CaseFace5 Posted December 9, 2018 Author New Member Report Share Posted December 9, 2018 hmm not sure I understand, I dont see any rectangle or selection tools like that? Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted December 9, 2018 Advanced Member Report Share Posted December 9, 2018 Paint Room > Then in the E-Panel select the Rectangle Lasso . then click and drag in the uv editor. Which you open in the Textures (top row). Quote Link to comment Share on other sites More sharing options...
