Advanced Member paulrus Posted March 2, 2009 Advanced Member Share Posted March 2, 2009 I've decided to give Windows 7 x64 a try and have run into a problem. When you use CTRL-P to send the layers to Photoshop it works fine - BUT when you try to save your changes, you get "Could not save C:\...\Layers.psd" because the file is locked." Any idea how to fix this? My entire workflow revolves around going back and forth to Photoshop. Thanks Paul Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 2, 2009 Share Posted March 2, 2009 I've decided to give Windows 7 x64 a try and have run into a problem.When you use CTRL-P to send the layers to Photoshop it works fine - BUT when you try to save your changes, you get "Could not save C:\...\Layers.psd" because the file is locked." Any idea how to fix this? My entire workflow revolves around going back and forth to Photoshop. Thanks Paul Try to run PS as administrator. Quote Link to comment Share on other sites More sharing options...
