Voxel room - Primitive Position Copy/Paste
blackant Master
Hello,
Today i was working on an object using voxels, and while sitting all objects in place, i had some complications, because each time i switch to a primitive to another, the memory use the last one for each tool.
wich can be great in many occasion but not this time.
Because sometimes, an object is only composed by few primitives, like a cone with on top of it a sphere, with an extrusion somewhere and a hole inside ....
Each time i have to place the next object manually, i have to go back to origin, or reset the pivot from the previous use, and so, put it with a bit less of precision than espected especially when the objects are not center somewhere.
so, my idea about this is simple:
just adding a copy button in the parameters to get position and rotation mainly, and a paste button to set it when needed.
maybe this parameters are already avaible somewhere, i'm not using voxels really often,
if so let me know.
thanks
