[Solved] Depth scanning window not appearing when baking
Makketronics
I am trying to bake an object  in Retopo room. When I click Bake W / Normal Map, I can choose Scan Depth Inside and outside, for the cage.
After I choose OK, I am prompted to choose Resolution. Normally I am asked to choose Scan Depth after adjusting cage. As a result, I am seeing "Transparent" areas in the bake.
Using 4.8.28 SL (64 bits). This used to work in this version before by the way. Any ideas how to enable that popup again?
  • Carlosan changed the title to [Solved] Depth scanning window not appearing when baking
