[Solved] 3d Coat curve stroke problem
GuidoG
  • New Member
Hi, I am new to 3dcoat and I am having a bit of a problem with the curve stroke. You see when I try to aply the curve stroke to a mesh I get the following error:
As you may notice the stroke is not under the designated curve. This seems to happen only with a hightpoly model I imported. However I can not figure out what might be the problem. Has this happened to you before? Do you have any idea on how to fix it? Thanks!
  • Carlosan changed the title to [Solved] 3d Coat curve stroke problem
