Omni-Moulage
[Solved] Supports for 3D Printing
Hi,
In order to use only one software: 3D-Coat, I would like to know if it is possible to add inside the "Adjust box" the "Supports" tool existing on 3DC-printing.
Unless this is automatically done after buying a 3DC-printing licence ?
Salut,
De façon à n'utiliser qu'un seul logiciel: 3D-Coat, Je voudrais savoir s'il est possible d'ajouter l'outil "support" dans la boite à outil "Ajuster" ?
A moins que celà soit automatiquement fait lorsqu'on achète une licence 3DC-printing ?
Can this be added by default, for 3DCoat Professional licenses? Users who spend nearly $400 should have access to the same tool, without having to buy another version of 3DCoat, IMO.
9 hours ago, Andrew Shpagin said:
Create empty file supports.dat in MyDocuments/3D-CoatV48/
Creating supports.dat will also work for users who have the Professional license of 3d-Coat like me? Or is this only for 3DC-Printing users?
I tried to create this file, but as my version is Professional it did not work ...
Yes.
Creating supports.dat will also work for users who have the Professional license of 3d-Coat.
28 minutes ago, Carlosan said:
Yes.
My 3D-Coat installation is based on the coat_data_path File.
I tried putting the file that Andrew spoke in
MyDocuments/3D-CoatV48/    but it did not work ...
Could you instruct me better how can I proceed?
Will I have to put the supports.dat that Andrew said in the Directory folder I wrote inside the coat_data_path?
Or do I have to put the same file (supports.dat) in both places (
MyDocuments/3D-CoatV48/ ) and (the folder of coat_data_path)?
thank you
...do I have to put the same file (supports.dat) in both places ( MyDocuments/3D-CoatV48/ ) and (the folder of coat_data_path)?
Yes
Yes
Great! I put the supports.dat in both directories and the tool appeared.
Thanks a lot for the help!
What I am saying is that customers/users of the Professional license shouldn't have to go through what amounts to a hack, in order to get a tool that should already appear in the app. 3DC Printing is effectively a cut down version (Sculpt Room) of 3DCoat. Anyone who spends nearly $400 for the Professional license should not have to buy a cut down version of what they already paid for, just to get one useful feature.
And for what it's worth, I don't know how to make a blank "supports.dat" file. I tried creating a blank text document and renaming it "supports.dat" but that doesn't work.
....nevermind. I tried it again, this time instead of saving it as an .rtf file first > renaming it, I just selected "text document" from the drop list of file formats > saved as "supports.dat"
Still, it should be a default feature so users don't have to do this.
IMO, you're right... Supports tool could already been installed by default in the 3d-coat professional license. Just like any other tool or function. The main reason is that all other programs are "subprograms" of the professional version of 3D-Coat.
Another important thing to remember and I do not know if this would have any influence, but when I do this supports.dat file, I have to put it in two different folders due to my installation (coat_data_path file) and honestly I do not know if I will have problems installing a newer version of 3D-Coat.
I think every time when I install a newer version of the program, I will have to create the supports.dat file in the Documments / 3dcoatV8 folder.
If I had not seen this topic (I thank the creator of this topic a lot, thank you @Omni-Moulage), I would never know that I could have the Supports tool in the 3D-Coat Professional license.
Please @Andrew Shpagin and developers, as a matter of common sense, include all the tools and functions by default in the 3D-Coat Professional license.
This way, it would prevent users from reporting to you program errors that users might have attempted to place files on the installation to obtain a tool or function from the program.
By the way, there's a serious Crash ERROR going on with me.
3D-Coat is behaving strangely. When I try to open a splash screen on the surface and voxels mode or file already saved, 3D-Coat displays an instability warning message and a screen appears to save, then a Crash window appears and the 3d-coat closes.
31.01.2019 4.8.33
- Enabled supports
6 hours ago, Carlosan said:
31.01.2019 4.8.33
- Enabled supports
Could I delete the files that I created (supports.dat) at the followings directories:
Documents\3D-CoatV48
        and
\pathto\3DCoatDataFiles (this directory is the path of the file: coat_data_path.txt of my installation)
Or if I delete, can some problems happen?
You can try it. Delete cant add any issue.
Hi  @Carlosan ! I just deleted the supports.dat file from the 2 directories and everything went fine.
3D-Coat opened with the supports tool by default.
Thank you!
