Contributor Rygaard Posted January 4, 2019 Contributor Report Share Posted January 4, 2019 Hey Everone! What happened to the Re-project Tool?I'm using the latest version of 3d-coat .31-SL. I tried to find the tool but it disappeared ...Does this disappearance have to do with this specific beta or something happened to remove this essential tool of the program?*** Please, the developers could return with this important tool (Re-project Tool) to the program?Thank you. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 4, 2019 Report Share Posted January 4, 2019 Preferences, show beta tools is = ON ? Quote Link to comment Share on other sites More sharing options...
Contributor Rygaard Posted January 4, 2019 Author Contributor Report Share Posted January 4, 2019 Yes... I always let show beta tools ON ... I don't know what happened... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 4, 2019 Report Share Posted January 4, 2019 Reported Quote Link to comment Share on other sites More sharing options...
Contributor Rygaard Posted January 4, 2019 Author Contributor Report Share Posted January 4, 2019 OK thank you for the attention... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 11, 2019 Report Share Posted January 11, 2019 4.8.32 - Enabled Reproject in SL version 1 Quote Link to comment Share on other sites More sharing options...
Contributor Rygaard Posted January 11, 2019 Author Contributor Report Share Posted January 11, 2019 @Carlosan Many thanks for informing me! I installed this new version and the tool is back!I was quickly using Reproject and I do not know if the inner preview and outer shell are working right ... I could not see if the preview is happening.Could you let me know if the preview of the tool is working as it should in your installation?thank you Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12, 2019 Report Share Posted January 12, 2019 * The preview is not happening, confirmed. And reprojection tool destroy Layer0 sculpt data. Reported. Thx //edit working fine on version 4.8.42 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 26, 2019 Advanced Member Report Share Posted January 26, 2019 It's not showing for me in version 4.8.32(DX64) or 4.8.32(GL64). Do I need to do a clean install? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 26, 2019 Report Share Posted January 26, 2019 Preferences, show beta tools... Is switched on ? Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 27, 2019 Advanced Member Report Share Posted January 27, 2019 Hi Carlson, Yep. Sorry for the late reply. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 28, 2019 Report Share Posted January 28, 2019 Are you working on Surface Mode on version 4.8.32 ? Try this command please. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 28, 2019 Advanced Member Report Share Posted January 28, 2019 (edited) I'm using 4.8.32. I have tried with surface and voxel mode. Show all tools in section didn't fix it. I also tried a clean install. Edited January 28, 2019 by bisenberger Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 28, 2019 Report Share Posted January 28, 2019 Try to delete all files MyDocs/3D-CoatV48/Options***.xml If it will not help, try to delete whole MyDocs/3D-CoatV48/ But keep backups it there is something important! Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 28, 2019 Advanced Member Report Share Posted January 28, 2019 (edited) I deleted the Options***.xml first and that didn't work. Tthen I deleted MyDocs/3D-CoatV38. Still not working. When I select Show Beta Tools it does add ExtrudeFaces to the Adjust tools though. Edited January 28, 2019 by bisenberger Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted May 23, 2019 Advanced Member Report Share Posted May 23, 2019 It never appeared in my 3D-Coat 4.8.37 version. On the YouTube 3D Coat Training Channel, I seen a comment where someone asked the same question. It looks like their solution was the SL installer. What is the SL installer? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 23, 2019 Report Share Posted May 23, 2019 Its an early build with sculpt layers, only for real enthusiasts - Use this build at your own risk! Download it here: http://pilgway.com/files/3dcoat/V4.8/3d-Coat-V4_8-39SL-64.exe Alternative link (starts to works ~1 hour after uploading to main server) http://3dcoat.com/files/3dcoat/V4.8/3d-Coat-V4_8-39SL-64.exe Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted May 24, 2019 Advanced Member Report Share Posted May 24, 2019 Thanks Carlosan 1 Quote Link to comment Share on other sites More sharing options...
