Applink Developer haikalle Posted February 2, 2019 Applink Developer Report Share Posted February 2, 2019 Hi! This feature was resently added into blender and it makes huge difference when sculpting. It would be nice feature to have in 3D-Coat. Basically what it does it will tries to create triangles edges into same direction with brush stroke. https://blenderartists.org/t/custom-build-dyntopo-improvement-toporake/1142166 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 2, 2019 Report Share Posted February 2, 2019 link This is because TopoRake is a modified smoothing routine, just like autosmooth but smarter. so It literally smoothes the mesh in the direction you paint but tries to preserve volume, which reduce the strength of the other brushes. Toporake will realign edges so they follow the flow of your sculpting. For instance if you carve a crease into a mesh, the edges will be aligned to create a more defined seam. Quote Link to comment Share on other sites More sharing options...
