Member sHAYM4N Posted February 15, 2019 Member Report Share Posted February 15, 2019 Hi guys, sorry for the inane question, but couldn't find details on it. Which is the proper way to install an update to 3DCoat? Uninstall first or over the top will be fine? I've normally only updated to be honest when reformatting my PC, so haven't really checked on this before, thanks! Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted February 15, 2019 Advanced Member Report Share Posted February 15, 2019 (edited) Hi, just install the latest version, it doesn't install over the version you have, you will then have two versions in your start menu. Then you can use the previous version also. I usually have about three on the go, then uninstall the oldest when I think the latest is stable for my purposes. All your settings are stored in a separate folder so they can be accessed by the new version. Edited February 15, 2019 by stusutcliffe 1 Quote Link to comment Share on other sites More sharing options...
Member sHAYM4N Posted February 15, 2019 Author Member Report Share Posted February 15, 2019 34 minutes ago, stusutcliffe said: Hi, just install the latest version, it doesn't install over the version you have, you will then have two versions in your start menu. Then you can use the previous version also. I usually have about three on the go, then uninstall the oldest when I think the latest is stable for my purposes. All your settings are stored in a separate folder so they can be accessed by the new version. Oh that's wicked thanks! Was hoping that was the case, but thought I'd better check Quote Link to comment Share on other sites More sharing options...
