New Member AlanSomething Posted March 1, 2019 New Member Report Share Posted March 1, 2019 Is there a way to determine the import settings for I used for an obj when I created a project? I Imported an object for Per Pixel Painting, and the image titled "Capture" is what I got. Great. However, when I tried to create a similar file, It came out looking like Capture 2. Capture 1 shows my settings that I thought I had used for the original file. Also, isn't there a way to set 3D Coat so it is more compatible with Maya? Quote Link to comment Share on other sites More sharing options...
New Member AlanSomething Posted March 1, 2019 Author New Member Report Share Posted March 1, 2019 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 1, 2019 Report Share Posted March 1, 2019 Hi Is there a way to determine the import settings for I used for an obj when I created a project? This feature is not implemented. 3DC remember import settings by session only. Quote Link to comment Share on other sites More sharing options...
New Member AlanSomething Posted March 1, 2019 Author New Member Report Share Posted March 1, 2019 Hey thanks for the quick reply! Can you please tell me how to import my object so it appears in the image titled "Capture". So it is smoothed and not faceted? I thought this was controlled by "Full UV set smoothing", or by the smoothing settings in general. I have tried adjusting all of the four drop down menu settings, but it doesn't seem to affect the model. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 2, 2019 Report Share Posted March 2, 2019 Before export it, was the model shade changed to smooth ? 3DC does not have tools to change from smooth shade to flat shade, that must be done before importing the model. Quote Link to comment Share on other sites More sharing options...
