New Member BobKotlinski Posted March 4, 2019 New Member Report Share Posted March 4, 2019 I just downloaded the trial version of 3DC-printing (v. 4.8.08) for MacOS, and it does not run. I get a "3D-Coat quit unexpectedly" error. I'm running OS 10.13.6 on a Late 2013 MacPro. Any suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 4, 2019 Report Share Posted March 4, 2019 Hello Is this information useful for you ? Ensure to check "System Preferences > Security & Privacy > click the "lock" > select "App Store and identified developers" (when only "App Store" is selected error message is displayed "3DCoat" can't be opened because it was not downloaded from the App Store) 3DCoat crashes on startup Quote Link to comment Share on other sites More sharing options...
New Member BobKotlinski Posted March 4, 2019 Author New Member Report Share Posted March 4, 2019 Thanks for your reply Carlosan! Unfortunately, that is not the issue, I think. "App Store and identified developers" is currently checked in my Security & Privacy settings. I opened the Package Contents of the application and ran the "3D-Coat" file inside the "MacOS" folder, and the application runs! (as long as I keep the terminal running.) It does give me this message in return, if anyone knows what it means: objc[66672]: Class FIFinderSyncExtensionHost is implemented in both /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit (0x7fff895fdcd0) and /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride (0x11ea69cd8). One of the two will be used. Which one is undefined. Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
SERGYI Posted March 5, 2019 Report Share Posted March 5, 2019 In Terminal clear quarantine attribute from folder "3DC-printing-1.1.09": $ xattr -dr com.apple.quarantine /Applications/3DC-printing-1.1.09/* If that didn't work do the following: 1. Check integrity of downloaded image:http://www.3d-coat.com/~sergyi/3DC-printing/3DC-printing-1.1.09.dmg File size is 142,312,944 bytes. Terminal command $ shasum 3DC-printing-1.1.09.dmg returnsa1f9263bff1df8f0942dfa65867605f0db77a9d3 2. Remove quarantine attribute from download image: $ xattr -d com.apple.quarantine 3DC-printing-1.1.09.dmg $ ls -l@ 3DC-printing-1.1.09.dmg (attribute "com.apple.quarantine" should gone) 3. Remove previous folder "/Applications/3DC-printing-1.1.09". Copy "3DC-printing-1.1.09" from disk image with cleared quarantine attribute into "/Applications" again. Quote Link to comment Share on other sites More sharing options...
New Member BobKotlinski Posted March 5, 2019 Author New Member Report Share Posted March 5, 2019 Wow! Thanks! Clearing the quarantine attribute did the trick! Quote Link to comment Share on other sites More sharing options...
