Gorbatovsky Posted January 26, 2023 Author Report Share Posted January 26, 2023 1 hour ago, aleksej said: What does 4 mean exactly? Welding tolerance is entered in pixels Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted January 26, 2023 Advanced Member Report Share Posted January 26, 2023 On 1/30/2022 at 3:24 PM, esepablo said: yes, i understand the feature is to build polygon with points, but why is it a feature to place point in empty space? im not trying to put points in empty space. when i click outside the model, to rotate, it puts points in empty space. is this normal behavior? i have to switch to a different brush everytime i want to rotate. There are certain tools in 3D Coat where you need to hold the 'alt' key to enable tumbling because those tools takeover left mouse click off the model. The sphere tool in Voxel sculpting mode is another example. Pressing the alt key will force navigation mode. so that you can tumble while your cursor is on top of the model as well. You could also tumble the view by dragging in the margin border around the 3d viewport, which also forces navigation mode. Hopefully you had already figured that out. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 17, 2023 Report Share Posted August 17, 2023 @Gorbatovsky 1 hour ago, Taros said: This is what we expect. Just a vertex distribution. Here an example from Blender: Quote Link to comment Share on other sites More sharing options...
