Reputable Contributor AbnRanger Posted June 8, 2020 Reputable Contributor Share Posted June 8, 2020 Hopefully it is just a small adjustment, but could we PLEASE change the old, 90's style spheres (POINTS & FACES and ADD/SPLIT tool) to small circles....sort of like selected Vertices, but maybe slightly larger in scale? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 8, 2020 Reputable Contributor Share Posted June 8, 2020 Just now, AbnRanger said: Hopefully it is just a small adjustment, but could we PLEASE change the old, 90's style spheres (POINTS & FACES and ADD/SPLIT tool) to small circles....sort of like selected Vertices, but maybe slightly larger in scale? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 8, 2020 Reputable Contributor Share Posted June 8, 2020 Another point of reference. Maya's retopo tools no doubt took some notes from 3DCoat's retopo tools...but changed the look of the points, which is cleaner and more simple looking. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 8, 2020 Share Posted June 8, 2020 11 hours ago, Rygaard said: @Gorbatovsky My congratulations for the excellent work developing fantastic tools. I am impressed with what you are demonstrating in the videos. I would like to ask you 2 questions. 1) Could you tell us, the videos you shared about KnifeAndProfile, AutoRetopo, SmartRetopo tools will be available when in 3D-Coat?2) Could I suggest a new tool in relation to Curves? - Bevel Curves Tool: After the user creates a new curve on the mesh surface, the "Bevel Curves Tool" through the curve created in the geometry, a temporary Preview would appear and allow the realization of custom bevels similar to the Coat Tool / Edge Shape = CostomShape and EdgeWidth properties (save / load Curves).So, after customizing the bevel in the Preview and the user would press the Apply button and the desired Bevel would happen DIRECTLY in the geometry. And at the same time this bevel would be created in a new Sculpt Layer (If the user checked the option create a new sculpt layer with this bevel). Making the process less destructive. This suggested tool (Bevel Curves Tool) would be to directly deform the geometry and not create another geometry on top as is the case with the Coat tool. Thank you Deforming geometry will be ugly because of polygons lack. Why not just do boolean? I understand instability, but diving a bit into the surface will solve the problem. Quote Link to comment Share on other sites More sharing options...
Contributor Rygaard Posted June 8, 2020 Contributor Share Posted June 8, 2020 1 hour ago, Gorbatovsky said: I didn't quite catch what you write. Let me try to explain it better. This tool (Bevel Curves Tool) would modify the edge directly from this geometry by applying a Customized Bevel similar to the features that exist in Coat Tool. But instead of creating another geometry in SculptTree, that bevel would be applied directly to the edge of Geometry or wherever the curve is around the geometry. It would be the same operation as a Bevel Tool that exists in the Blender program and other 3d programs. Therefore, it would be basically the operation of the Coat Tool, but applying the bevel physically deforming wherever the curve is. And when the user wanted to apply the Bevel, the user could activate an option to create a new Sculpt Layer so that the procedure is non-destructive. 46 minutes ago, Andrew Shpagin said: Deforming geometry will be ugly because of polygons lack. To avoid this problem, we could have something similar to Remove Stretching or Add Local Subdivision or Density within the property options and thus we would have a perfect and quality Bevel. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted June 9, 2020 Advanced Member Share Posted June 9, 2020 (edited) Hi, It would be interesting to have retopo tool using angle based parameter, as efficient as Blender decimate modifier. This has many uses for low poly quick retopo. And this avoids having lot of not necessary vertex when the model is more hard surface planes. With options like delimit by normal, material, UV Edited June 9, 2020 by Ratchet 3 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 17, 2020 Share Posted September 17, 2020 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted September 19, 2020 Advanced Member Share Posted September 19, 2020 (edited) Good addition to 3D Coat retopo tools. Edited September 19, 2020 by Ratchet Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 18, 2020 Share Posted October 18, 2020 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 21, 2020 Share Posted October 21, 2020 Quote Link to comment Share on other sites More sharing options...
Gorbatovsky Posted October 21, 2020 Author Share Posted October 21, 2020 Добавлена возможно тонкой настройки границы сетки в режиме Quadrangulation. Added possibly fine-tuning the mesh boundary in Quadrangulation mode. 3 Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted November 5, 2020 Advanced Member Share Posted November 5, 2020 On 3/13/2019 at 3:50 PM, Carlosan said: Hi Alex Although I do believe that the Retopo room needs to be modernized, both in the performance and in the administration of files; I think it's important to mention that in the long term, retopo room should become a CAD modeler. As i remember time ago Andrew helps Wings3D development with some lines of code. Being able to gradually convert the Retopo room on CAD modeling room would greatly help the insertion of 3DC in the market as a total modeling solution. Thx and best regards CA 0000616: Possibility to create and manipulate nurbs surfaces and transform them to voxels As a long time user of Wings3D and Wings3D forum member I was not aware of Andrews involvement with Wings3D. I still like to fire up that app on ocassion. 1 Quote Link to comment Share on other sites More sharing options...
Gorbatovsky Posted November 5, 2020 Author Share Posted November 5, 2020 4 hours ago, kenmo said: Being able to gradually convert the Retopo room on CAD modeling Thank you. We added a Modeling room in the 3DCoat 2020. 2 Quote Link to comment Share on other sites More sharing options...
Member hansolocambo@gmail.com Posted December 28, 2020 Member Share Posted December 28, 2020 (edited) I've been using 3D-Coat only for retopology and unwrapping for about 5 years. For a long time 3D-Coat was crashing when exporting retopo as fbx. But the fbx export changed to 2015 and this worked better. Anyway, because of that export issue, I got used to save the file (3b) and only then export as fbx. If 3D-Coat crashed I could always reopen my last save and retry to export as fbx. Which usually worked fine. But since a recent update (about a month or two ago?), when 3D-Coat decides to crash while exporting the retopo (obj, fbx or any other format doesn't change a thing), it doesn't matter how many times I reload the last save an retry : the retopo is dead. I can reopen my file, my work is there in the retopo room. I can work on it. But I can't export it anymore. I lost so many hours in the last 2 months that I moved to 3DS Max and its ultra unintuitive shortcuts, its ugly display and terrible viewport controls, because it was the only solution to work in a more stable environment. You want to improve the retopo room ? Give us a way to check the mesh for eventual errors that would explain why a mesh is crashing the app everytime we try to export it. As it is now, it's just not usable anymore. And I very much regret it. Edited December 28, 2020 by hansolocambo@gmail.com 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted December 29, 2020 Advanced Member Share Posted December 29, 2020 (edited) I recently came across this plugin. Something like this would be great in 3D Coat. https://blendermarket.com/products/softwrap You guys are almost there already with the cloth tool. Edited December 29, 2020 by gbball 1 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted December 29, 2020 Share Posted December 29, 2020 13 hours ago, hansolocambo@gmail.com said: I've been using 3D-Coat only for retopology and unwrapping for about 5 years. For a long time 3D-Coat was crashing when exporting retopo as fbx. But the fbx export changed to 2015 and this worked better. Anyway, because of that export issue, I got used to save the file (3b) and only then export as fbx. If 3D-Coat crashed I could always reopen my last save and retry to export as fbx. Which usually worked fine. But since a recent update (about a month or two ago?), when 3D-Coat decides to crash while exporting the retopo (obj, fbx or any other format doesn't change a thing), it doesn't matter how many times I reload the last save an retry : the retopo is dead. I can reopen my file, my work is there in the retopo room. I can work on it. But I can't export it anymore. I lost so many hours in the last 2 months that I moved to 3DS Max and its ultra unintuitive shortcuts, its ugly display and terrible viewport controls, because it was the only solution to work in a more stable environment. You want to improve the retopo room ? Give us a way to check the mesh for eventual errors that would explain why a mesh is crashing the app everytime we try to export it. As it is now, it's just not usable anymore. And I very much regret it. Please send me the example scene to the andrewshpagin@gmail.com Quote Link to comment Share on other sites More sharing options...
Advanced Member L'Ancien Regime Posted January 3, 2021 Advanced Member Share Posted January 3, 2021 On 12/29/2020 at 12:00 AM, gbball said: I recently came across this plugin. Something like this would be great in 3D Coat. https://blendermarket.com/products/softwrap You guys are almost there already with the cloth tool. Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted January 3, 2021 Advanced Member Share Posted January 3, 2021 1 hour ago, L'Ancien Regime said: Yeah, Zwrap is what I saw initially, and I thought that would be a great retopo addition in 3D Coat. And then being able to pull in some textures from XYZTextures. 1 Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 3, 2021 Share Posted January 3, 2021 I think I've actually done this before if I had a similar enough model, just loading it in the retopo room with snap it to the sculpted mesh. 1 Quote Link to comment Share on other sites More sharing options...
Member hansolocambo@gmail.com Posted January 6, 2021 Member Share Posted January 6, 2021 I didn't keep any of the retopo files that kept crashing. I thought it was because of a wireframe error (usually caused by the retopo symmetry) but I retopo a mesh every 3 or 4 days and I tried many ways to avoid the bug. Thing is : it's not a wireframe error. Last thing I tried, before moving to 3DS Max (and latest ZBrush versions) for retopo, was to delete all the retopo object, but 1 quad. And even this 1 quad would make the export crash every time. So it's just the 3b retopo scene that becomes unstable for some reason and then the mesh is lost. Retopo object is there, but cannot be exported. I could work on 3D-Coat again and as soon as it happens, I could send you a file. But this has been happening for a while now and extremely often. Shouldn't be hard to reproduce the error I'm working on a cartoon environment. I'm gonna do some retopo again, then, in 3D-Coat. As soon as it happens again, I'll send you the file. Quote Link to comment Share on other sites More sharing options...
Member hansolocambo@gmail.com Posted January 6, 2021 Member Share Posted January 6, 2021 (edited) On 12/29/2020 at 12:18 PM, Andrew Shpagin said: Please send me the example scene to the andrewshpagin@gmail.com I usually don't keep retopo files once the mesh is done. And I certainly didn't keep 3b retopo files that kept crashing I thought it was because of a wireframe error (usually caused by the retopo symmetry) but I retopo a mesh every 3 or 4 days and I tried many ways to avoid the bug. Thing is : it's not a wireframe error. Last thing I tried, before moving to 3DS Max (and latest ZBrush versions) for retopo, was to delete all the retopo object, but 1 quad. And even this 1 quad would make the export crash every time. So it's just the 3b retopo scene that becomes unstable for some reason and then the mesh is lost. Retopo object is there, but cannot be exported. I could work on 3D-Coat again and as soon as it happens, I could send you a file. But this has been happening for a while now and extremely often. Shouldn't be hard to reproduce the error I'm working on a cartoon environment at the moment. I'm gonna do some retopo again, then, in 3D-Coat. As soon as it happens again, I'll send you the file. Cheers. Edited January 6, 2021 by hansolocambo@gmail.com 1 Quote Link to comment Share on other sites More sharing options...
Gorbatovsky Posted March 20, 2021 Author Share Posted March 20, 2021 Demonstration of new tools in the Modeling room with a Modeling of a rhinoceros -Swept Surface N-Gener 0:10; 9:25 -Smart Extrude 5:28 -Alignment Vertex's 7:30 -Spine Tool in Spline mode 15:20 -Knife - polygon option 11:56 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted March 24, 2021 Advanced Member Share Posted March 24, 2021 Is there an English version of this video? Cheers Quote Link to comment Share on other sites More sharing options...
Gorbatovsky Posted March 24, 2021 Author Share Posted March 24, 2021 9 minutes ago, kenmo said: Is there an English version of this video? Cheers There is no English version yet. I have problems with pronunciation. But, you can turn on subtitles with English translation. Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted March 24, 2021 Advanced Member Share Posted March 24, 2021 Thanks for that tip. But I find videos with captions or subtitles too hard to follow as trying to read text and follow the mouse pointer is very difficult. Cheers & take care. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted March 24, 2021 Share Posted March 24, 2021 5 hours ago, Gorbatovsky said: There is no English version yet. I have problems with pronunciation. But, you can turn on subtitles with English translation. Actually that one does not have English. It's only auto-generated Russian. Quote Link to comment Share on other sites More sharing options...
Contributor Sorn Posted March 25, 2021 Contributor Share Posted March 25, 2021 19 hours ago, philnolan3d said: Actually that one does not have English. It's only auto-generated Russian. You can activate English subtitles with auto-translation pressing the settings icon next to the subtitles icon. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted March 25, 2021 Reputable Contributor Share Posted March 25, 2021 On 3/24/2021 at 9:23 AM, kenmo said: Thanks for that tip. But I find videos with captions or subtitles too hard to follow as trying to read text and follow the mouse pointer is very difficult. Cheers & take care. We will have something up shortly 1 1 Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted March 25, 2021 Share Posted March 25, 2021 6 hours ago, Allabulle said: You can activate English subtitles with auto-translation pressing the settings icon next to the subtitles icon. Oh OK I was watching on my phone and it doesn't have that option unless you switch to desktop mode. Quote Link to comment Share on other sites More sharing options...
Advanced Member kenmo Posted March 26, 2021 Advanced Member Share Posted March 26, 2021 9 hours ago, AbnRanger said: We will have something up shortly Well, if you are the author of the video we can all be assured it will be of very high quality. I've always enjoyed your tutorials, videos and tips. Look forward to it. Quote Link to comment Share on other sites More sharing options...
