Member Ivanxof Posted March 23, 2019 Member Share Posted March 23, 2019 Hello, My 3D-Coat works really slow/lags when my Wacom(Cintiq Pro 24) is turned off. If I turn on my wacom it instantly makes 3D-Coat works normally. I have tried updating my drivers, changing main monitors, I even reinstalled Windows 10. Im currently using v4.8.36, I have tried others versions as .34, .33, .32, .31... All of them lags. My hardware: i7-6700K, 1080TI, 16GB DDR4. What can I do? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/23361-3d-coat-lagsslow-when-wacom-is-turned-off/ Share on other sites More sharing options...
Carlosan Posted March 24, 2019 Share Posted March 24, 2019 Hello Please try this On 3/6/2017 at 4:17 PM, SERGYI said: I have built separate Wacom tablet test. Please download and try this test:http://www.3d-coat.com/~sergyi/Tests/3D-Coat-Pressure-Test.zip This is the engine of "3D-Coat" tablet input. It will show does the pen send pressure information to the application and you can see how application behaves during Wacom input. That zip file besides executables also contains two screenshots which show how it should look like. Please look at FPS. Please try both executables (DX - DirectX, and GL - OpenGL). Do you see similar problems? Please contact me directly "support DOT linux AT 3dcoat DOT com". Quote Link to comment https://3dcoat.com/forum/index.php?/topic/23361-3d-coat-lagsslow-when-wacom-is-turned-off/#findComment-159797 Share on other sites More sharing options...
Carlosan Posted March 24, 2019 Share Posted March 24, 2019 I forgot to ask, sorry Edit > Preferences > General > Tablet Interface > select WinTab Windows has it’s own Tablet drivers that seem to interfere with Wacom’s drivers. After installing Wacom’s drivers, the Windows driver is fairly pointless so all you have to do is disable it. - Here is how: Go to Control Panel -> Administrative Tools -> Services Scroll down to “Tablet PC Input Service” -> Right Click and choose “Stop” To keep it permanently disabled after start up go to properties and changed the “startup type:” to “Disabled. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/23361-3d-coat-lagsslow-when-wacom-is-turned-off/#findComment-159798 Share on other sites More sharing options...
Member Ivanxof Posted March 26, 2019 Author Member Share Posted March 26, 2019 I tried the zip you sent me... And it lags too.. tried both DX and OpenGL. Then tried to look for the service and it is not there. So I'm not sure what is happening. Looks like the only workaround is to always use 3D Coat with the Cintiq turned on. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/23361-3d-coat-lagsslow-when-wacom-is-turned-off/#findComment-159828 Share on other sites More sharing options...
Carlosan Posted March 26, 2019 Share Posted March 26, 2019 Hi As i said, please send support-related questions to Sergii Kryzhanovskyi atsupport.linux@3dcoat.com Thx Quote Link to comment https://3dcoat.com/forum/index.php?/topic/23361-3d-coat-lagsslow-when-wacom-is-turned-off/#findComment-159829 Share on other sites More sharing options...
