On start-up "3DCoat for Linux" automatically enables tablets which it is able to recognize. Otherwise the tablet should be enabled manually by defining the environment variable "COAT_PEN" equals the name of the input stylus device. For example: export COAT_PEN="Wacom Intuos3 4x6 Pen stylus"
Since "3DCoat 4.9.70 for Linux" it outputs into the Terminal the list of your input devices. Please see the attached screenshot as an example. You have to send a screenshot with the name of your input stylu
Works on 20.10 too.
It might happen that spacenavd service is not started, and 3dcoat will crash too. So make sure that you start spacenavd service.
sudo service spacenavd start
In today's build 2023.08 for Linux there is a debug output from the file dialog into the Terminal: https://pilgway.com/~sergyi/links-Linux.html
In case of a file dialog crash please send the output to sergkryzh AT gmail dot com.
1. Linux is a family of operating systems. The "3DCoat" executable has been built under "Ubuntu 20.04". This is noted in the "Downloads" section on the site and inside download links. Compatibility with other distros is not guaranteed.
2. In "3DCoat 2023.27" for Linux Ubuntu there are two executables. One has been built under Ubuntu 20.04 (Python 3.8). The other one is under Ubuntu 22.04 (Python 3.10). Is this a good idea? Please provide your feedback on running these executables directly to m
I just wonder, one of 3dc users fixed 3dc 'open file dialog' crash - by switching to different file manager. Is there option, in 3DC, to tell it to use 'nautilus' file manager (from gnome) rather than 'dolphin' (from kde)? I know that firefox has option - to tell it which file manager it should use. Maybe this could fix the crashes for me (I'm on manjaro - kde - which uses Dolpin file manager)
Posted by SERGYI,
2 reactions
Go to this post
Posted by 4museman,
0 reactions
Go to this post
Posted by SreckoM,
1 reaction
Go to this post
Posted by SERGYI,
3 reactions
Go to this post
Posted by SERGYI,
1 reaction
Go to this post
Posted by JoseConseco,
0 reactions
Go to this post
