Linux updates news
foremancr
I have finished the "TestStroke" framework. All old code that uses X11 has been removed. Only plain GTK3 calls remain. Modern OpenGL uses the appropriate GTK3 code instead of the old X11. The stylus and eraser code are replaced with appropriate new GTK3 structures. Press the key "O" for the "Load Image" dialog. Key "S" for the "Save Image" dialog. Key "B" for the "Browse for Folder" dialog. Key "I" for the "Input Text" dialog. The download link is here:
https://pilgway.com/~sergyi/links-Linux.html
Using the finished framework from the "TestSroke", I built the "3DCoat" from the repository. The current version is "2024.27-01". The "3DCoat" building process incorporates more libs than the "TestStroke". These libs are dl, expat, util, fbxsdk, and python3.8. It is essential to ensure that these libs do not break the "3DCoat" behavior compared to the "TestStroke". If the file dialogs are successfully working on your system in the "TestStroke", they should work in the "3DCoat" too. The link to the "3DCoat" build is in the links file above. Note, that the "3DCoat 2024.27-01" has visual glitches that I will investigate. For now, focus on running the executable and displaying the file dialogs. Please provide feedback here or on my email sergkryzh AT gmail dot com.
  • Like 3
On 7/27/2024 at 2:27 AM, mmFX said:
I'm not an expert but would it be easier to port the software on QT instead of GTK?
There is no simple solution for the "3DCoat", mainly because it is a Windows-only app. I am porting the central part of the "3DCoat" code that doesn't have Windows-specific calls by isolating that code with custom-developed layers. Whatever libraries those layers will use will not make the process simpler.
The Ubuntu distro was chosen because it is simply available in WSL, under which "3DCoat" is built. The migration to GTK3 from GTK2 will hopefully allow "3DCoat" to work successfully on other distros.
On 7/22/2024 at 9:21 PM, Jorge said:
Unzip into any folder. For example, "Downloads", "Desktop", "Home". The error "Couldn't make the context current" has been investigated and fixed. Please re-download and try the following:
Note, that the current "3DCoat 2024.27-01" has visual glitches that are under investigation.
On EndavourOS (Arch Linux variant), GNOME 46.5 and Wayland, after unpacking the 3DCoat-2024.27-01.tar.bz2 file and running ./3dcoat I get this:
$>./3dcoat                                    Exit code: 134
Gdk-Message: 18:00:01.039: Unable to load sb_up_arrow from the cursor theme
Gdk-Message: 18:00:01.039: Unable to load circle from the cursor theme
I tried changing the cursor theme but it says something very similar, but slightly different cursor theme error message.
$>./3dcoat        Exit code: 255
Gdk-Message: 18:06:29.629: Unable to load sb_up_arrow from the cursor theme
Gdk-Message: 18:06:29.629: Unable to load tcross from the cursor theme
free(): invalid pointer
zsh: IOT instruction (core dumped)  ./3dcoat
3DCoat just doesn't launch after that.
Edit:
I tried it in Gnome X11 and it launches successfully, but crashes on attempting to save the scene to a file.
Edited by Sorn
Was able to launch 3d coat, but there are viewport errors. The grid overlaps all models in voxel and surface mode. Models themselves have strange artifacts, like objects are confused about what is in front or occluded. Showing 385FPS when vertical sync is enabled in prefereces. Working with a fresh install and fresh 3DCoat documents folder.
image.thumb.png.b81318711fd34cb85a3c5008524bae1d.pngimage.thumb.png.bde44dd8357fd20d94951a56d11b78de.png
@SERGYI
Wow, finally new update, unstable version, but still :rofl: I'm actually very glad.
I made some test, and found a few bugs. I decided to make a video about my test results, i hope it will be helpful for you.
I put a link to my MEGA drive.
https://mega.nz/file/VSdkzBDB#NRXeFKPlngXfYbho8z0CEBbZxBdcAf-duB5OqVcqkFA
Also i leave here, a short text version.
  • File dialog in general works fine, I've got no crushes, but hotkeys and function for basic file manipulation don't work or don't exist (like rename, delete, move files). Only create folder exist.
  • Can't change width of "Size" column in File dialog.
  • 3DCoat and TestStroke can't recognize my tablet Huion HS610. It behaves only like mouse.
  • Can't import my custom sculpt shaders from 2024.24 version.
  • Reference image always display on the top by overlapping my sculpt with this.
  • CastShadow and Incremental Render functions brake viewport and interface refresh.
  • Show Python Console - not working, do nothing.
  • Realtime Render - not working, but i can do render to file.
  • 3DCode broke PSD alpha brushes after import.
  • 3dCoat runs and closes with console errors.
    image.thumb.png.9adc02156d4063d9547167a907cbcafa.pngimage.thumb.png.84631496cebfdc842d5d6ba300084082.pngimage.png.040874700d82e121f5b1ced62a3e06c6.png
Edited by Grakino
  • New Member
Hi, I have tested version 2024.27-01 on Opensuse Tumbleweed 20240916 with KDE Plasma 6.1.5, X11 and we have the same problem when opening any type of file the program closes suddenly. It does not show errors in the console. It does not even allow opening the file to load the license. I had performed tests with TestStroke Build Sep 15 2024 and the dialog box to open and save files works correctly. But in 3DCoat 2024.27-01 it does not work.
14 hours ago, Grakino said:
@SERGYI
When you run 3D-Coat using shell, you need to add the environment variables to your shell configuration. Like this:
echo "export PYTHONHOME=/usr/bin/python3" >> ~/.bashrc
echo "export PYTHONPATH=/usr/lib/python3" >> ~/.bashrc
source ~/.bashrc
This will fix HOME and PATH being not set.
GTK errors might not always be related to GTK itself. They could stem from mismatched themes, system dialogs, or library conflicts in KDE. It’s recommended to test GTK apps in their native environments like GNOME or XFSE.
Edited by Sakru
  • Thanks 2
If you're experiencing crashes, try testing the program using strace.
strace ./3dcoat 2> log.txt
Here is what i found myself.
The goal of this test was to analyze the stability and memory usage
Steps taken:
GDB:
1. Launched 3DCoat with GDB to capture the backtrace of any crashes. The program encountered a segmentation fault at xmlDictFree (dict=0x96e4540) in the librsvg module, specifically within the GTK icon loading system. <- i tried to open a project
2. GDB backtrace showed that the crash was triggered when handling SVG images, possibly during GTK theme loading.
Valgrind Memory Analysis:
Run 3DCoat under Valgrind’s memory checker (Memcheck) to detect memory errors.
1, Valgrind reported multiple warnings regarding unsupported compression types when reading debug symbols from system libraries like libgtk-3, libcairo, and others. This limits my ability to provide detailed memory analysis for these libraries.
2. Several errors related to conditional jumps based on uninitialized values were detected. One of these errors stemmed from the calculate_path function, which is involved in Python’s path calculation in the application. The program attempted to read invalid memory, causing segmentation faults. This was traced back to the calculate_path function and ultimately tied to the handling of Python configuration initialization.
The tests were done hastily. I’m not sure if this will help anyone or provide the developers with new information (probably not), but I can send the logs if needed.
Edited by Sakru
Try this:
sudo apt install adwaita-icon-theme-full
source ~/.bashrc
Thank you!. At least HOME and PATH problem has been solved.
  • New Member
Hi when I run it with:
and I try to load the license file it suddenly closes
I got this:
newfstatat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//globs2", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//globs", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//magic", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//aliases", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//subclasses", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//icons", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/home/jfespinal/.local/share/flatpak/exports/share/mime//generic-icons", O_RDONLY) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//mime.cache", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//globs2", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//globs", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//magic", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//aliases", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//subclasses", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//icons", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/var/lib/flatpak/exports/share/mime//generic-icons", O_RDONLY) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/local/share/mime//mime.cache", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/local/share/mime//globs2", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/local/share/mime//globs", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/local/share/mime//magic", 0x7ffd15fb8940, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/share/mime//aliases", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/share/mime//subclasses", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/share/mime//icons", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/local/share/mime//generic-icons", O_RDONLY) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/share/mime//mime.cache", {st_mode=S_IFREG|0644, st_size=175444, ...}, 0) = 0
openat(AT_FDCWD, "/usr/share/mime//mime.cache", O_RDONLY) = 40
fstat(40, {st_mode=S_IFREG|0644, st_size=175444, ...}) = 0
mmap(NULL, 175444, PROT_READ, MAP_SHARED, 40, 0) = 0x7f184c744000
close(40)                               = 0
newfstatat(AT_FDCWD, "/usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so", {st_mode=S_IFREG|0755, st_size=14336, ...}, 0) = 0
openat(AT_FDCWD, "/usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so", O_RDONLY|O_CLOEXEC) = 40
read(40, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
fstat(40, {st_mode=S_IFREG|0755, st_size=14336, ...}) = 0
mmap(NULL, 16512, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 40, 0) = 0x7f184c73f000
mmap(0x7f184c740000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x1000) = 0x7f184c740000
mmap(0x7f184c741000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x2000) = 0x7f184c741000
mmap(0x7f184c742000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x2000) = 0x7f184c742000
close(40)                               = 0
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 40
fstat(40, {st_mode=S_IFREG|0644, st_size=137911, ...}) = 0
mmap(NULL, 137911, PROT_READ, MAP_PRIVATE, 40, 0) = 0x7f184940f000
close(40)                               = 0
openat(AT_FDCWD, "/lib64/librsvg-2.so.2", O_RDONLY|O_CLOEXEC) = 40
fstat(40, {st_mode=S_IFREG|0755, st_size=6539792, ...}) = 0
mmap(NULL, 6542440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 40, 0) = 0x7f1819400000
mmap(0x7f18194a4000, 3649536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0xa4000) = 0x7f18194a4000
mmap(0x7f181981f000, 1658880, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x41f000) = 0x7f181981f000
mmap(0x7f18199b4000, 565248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x5b3000) = 0x7f18199b4000
close(40)                               = 0
openat(AT_FDCWD, "/lib64/libxml2.so.2", O_RDONLY|O_CLOEXEC) = 40
fstat(40, {st_mode=S_IFREG|0755, st_size=1498816, ...}) = 0
mmap(NULL, 1501280, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 40, 0) = 0x7f1848091000
mmap(0x7f18480c7000, 925696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x36000) = 0x7f18480c7000
mmap(0x7f18481a9000, 303104, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x118000) = 0x7f18481a9000
mmap(0x7f18481f3000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x162000) = 0x7f18481f3000
mmap(0x7f18481ff000, 2144, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f18481ff000
close(40)                               = 0
openat(AT_FDCWD, "/lib64/glibc-hwcaps/x86-64-v3/liblzma.so.5.6.2", O_RDONLY|O_CLOEXEC) = 40
fstat(40, {st_mode=S_IFREG|0755, st_size=235640, ...}) = 0
mmap(NULL, 233504, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 40, 0) = 0x7f18489ac000
mmap(0x7f18489b0000, 163840, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x4000) = 0x7f18489b0000
mmap(0x7f18489d8000, 49152, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x2c000) = 0x7f18489d8000
mmap(0x7f18489e4000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 40, 0x38000) = 0x7f18489e4000
close(40)                               = 0
mprotect(0x7f18489e4000, 4096, PROT_READ) = 0
mprotect(0x7f18481f3000, 45056, PROT_READ) = 0
mprotect(0x7f18199b4000, 561152, PROT_READ) = 0
mprotect(0x7f184c742000, 4096, PROT_READ) = 0
munmap(0x7f184940f000, 137911)          = 0
futex(0x7f1851bf7f78, FUTEX_WAKE_PRIVATE, 2147483647) = 0
getrandom("\x9d\xe8\xe0\x32\x30\x0d\x9b\x22\x92\xd8\x20\xcd\xc3\xd5\xc3\xd4", 16, GRND_INSECURE) = 16
futex(0x40c2be8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
close(35)                               = 0
writev(2, [{iov_base="double free or corruption (out)", iov_len=31}, {iov_base="\n", iov_len=1}], 2double free or corruption (out)
) = 32
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f184c73e000
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
gettid()                                = 22313
getpid()                                = 22313
tgkill(22313, 22313, SIGABRT)           = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=22313, si_uid=1000} ---
+++ killed by SIGABRT (core dumped) +++
Aborted (core dumped)
I hope you can see something
I got this:
close(40)                               = 0
close(40)                               = 0
close(40)                               = 0
close(40)                               = 0
close(40)                               = 0
close(40)                               = 0
close(35)                               = 0
) = 32
gettid()                                = 22313
getpid()                                = 22313
Sorry i was very busy last few days.
I'm trying to understand what this report is about, but i really can find any clue.. i see you are trying to run /home/jfespinal/.local/share/flatpak/exports/share/mime/ but how is it related to 3D-Coat?
You are trying to activate Linux version of 3D-Coat? If yes, then i would recommend to run it using Bottles, because as of right now Linux version is broken. We can continue in this thread - https://3dcoat.com/forum/index.php?/topic/30731-3dcoat-202406-crashes-on-recent-linux-distros/#comment-196389
Edited by Sakru
Hi, in case anyone wishes to try 3DCoat 2024.27.01 on an Ubuntu image created with distrobox inside an Arch variant distribution, here's a link of what I tried:
If you have a better working solution please do chime in. :)
