Member andykarta Posted April 2, 2019 Member Report Share Posted April 2, 2019 (edited) When I export my texture with the obj from the file menu it's way too bright. Even when I turn off all the other channels, no change. I then export the color texture through the texture menu and it's right. Why won't it export the same way when I export all the texture channels at once from the File menu? Are other channels getting ruined too? Should I just export every channel separately until this is fixed? Is it some arcane setting I'm not setting? Edited April 2, 2019 by andykarta needed to add that it's not other channels. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 2, 2019 Report Share Posted April 2, 2019 Hi Are you using latest version ? I cant replicate this issue using version 4.8.36 - My set Textures > Textures import/export workflow = roughness/metalness View > GGX, Burley12 Quote Link to comment Share on other sites More sharing options...
