[Solved] Moving multiple curve points
dniitall
is there a way of moving multiple curve points? this would make my life sooo much easier, but i can't seem to find an answer
TIA.
[edit]
ok. i've found "Edit Points". is this the only way of doing it? is there no visual way?
Edited by dniitall
hi.
nope. i meant i want to be able to move the whole curve. all points together at the same time. eg. if i need to set 25 point deeper inside a surface. in other words something that can't be fixed with editing of the profile. i know i can fix it with the "edit points" but maaaaan, that's a chore from hell if i have lots of points. probably quicker to move each one manually :/
  • Carlosan changed the title to [Solved] Moving multiple curve points
  • 9 months later...
Thanks again for the quick reply.
Just to clarify, removing the OpenCL.dll file from the older version did not seem to work for me. But, I just installed the newer version (4.9.21) and it is fixed.
I will just continue with the newer version of 3D Coat. Thanks for the help.
