Member Leigh Posted April 17, 2019 Member Report Share Posted April 17, 2019 I have having some very annoying issues with shader preview icons not previewing correctly (see images). At first it was happening with the Metal shader previews... which I have just put up with in the hope that they would be fixed after updating the software, but they are still not displaying correctly. Now my Polymer previews are also doing this after last night when I right clicked one of the Polymer shaders and either clicked on either Rename Shader, Construct New Shader or Edit Permanent Shader Settings (I can't remember which one). At first it was just the one preview that was not displaying correctly, I read the thread, https://3dcoat.com/forum/index.php?/topic/22839-solved-shader-preview-problem/ so tried right clicking and clicking Refresh this Preview... no luck, so tried right clicking and selecting Refresh All Previews... which caused ALL the Polymer shader previews to display incorrectly. Any help would be appreciated!! I am still a new user so maybe I just did something wrong? Really love this software though for the main part! Thanks guys. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 17, 2019 Report Share Posted April 17, 2019 Hi Are you using latest version 4.8.38 ? Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 17, 2019 Author Member Report Share Posted April 17, 2019 Sorry Carlosan, forgot to mention... 4.8.37 which I installed two days ago. Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted April 17, 2019 Advanced Member Report Share Posted April 17, 2019 This has been broke for me for a long time . (38... still broke) So you are not alone! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2019 Report Share Posted April 18, 2019 Are your graphic driver up to date ? Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 18, 2019 Author Member Report Share Posted April 18, 2019 6 hours ago, Carlosan said: Are your graphic driver up to date ? Carlosan - Yes graphics drivers are all up to date (I am running a GeForce GTX960). From the comments (those that are actually relevant to this thread!), I am not alone on this... the only other details I can recall are that I was in the Sculpt workspace working in voxel mode and right clicked a shader, selecting either Rename Shader, Construct New Shader or Edit Permanent Shader Settings (can't remember which), when it started happening. Emi & Lizbot... I do not see how your comments relate to the heading of this thread (if it does and you have a potential solution, please let us know, if not, might be best to start another thread so people having similar issues as yours can find a solution easier or help you out. Thankyou) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2019 Report Share Posted April 18, 2019 Did you install the program using the default parameters? or you installed it on another hard drive that is not C: \ Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 19, 2019 Author Member Report Share Posted April 19, 2019 I used all of the default parameters Carlosan... using Windows 10. Also after installation I made sure not to launch from the popup window that appears after installation which states not to launch from it if you are using Windows 10. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 19, 2019 Report Share Posted April 19, 2019 Hi Your issue was reported to support team. I hope they share a quick solution. Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 19, 2019 Author Member Report Share Posted April 19, 2019 Thanks Carlosan Happy to give them as much info as I can or test a fix on my setup if needed. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 19, 2019 Report Share Posted April 19, 2019 Could you do a little test ? Please install this shader using Install Extension command metalGold2.3dcpack Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 20, 2019 Author Member Report Share Posted April 20, 2019 Thanks Carlosan... that one works fine now. I havent right clicked and tried to edit the shader or tried any of those options... which I think is what I did to break it originally. Let me know if you want me to test that as well. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 20, 2019 Report Share Posted April 20, 2019 I am afraid that last option will be uninstall and delete manually all 3DC folders at programa files and documents. Make a copy first if you have any sensible info added as custom presets or smart materials. Then install again. If you like please send support-related question about this issue at support@3dcoat.com Thx Quote Link to comment Share on other sites More sharing options...
Member Leigh Posted April 21, 2019 Author Member Report Share Posted April 21, 2019 On 4/19/2019 at 7:54 PM, Carlosan said: Thanks again for your help. So there is no way just to reinstall the metal and polymer shaders? Only asking because the metal you sent works fine. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 21, 2019 Report Share Posted April 21, 2019 I was testing latest version and suddenly, after use Transpose tool all shaders turn black. After 2 restarts and unfroze all models shaders are ok again, very strange. Bug was reported, i hope dev team can find a solution onto next release. Quote Link to comment Share on other sites More sharing options...
