Member Marci Posted April 22, 2019 Member Report Share Posted April 22, 2019 (edited) I just upgraded to the latest version and activated "AutoZipScenes" but it takes quite a while to compress the .3b file. Can someone from the team tweak the compression to "Fastest"? I used 7-ZIP to manually zip a file and when chaning the compression level from NORMAL to FASTEST it still gave me a good compression ratio (less than 5% difference in compressed file size) but the compression time was reduced by more than 50%. It's quite annoying to wait for the program to compress a simple file (less than 130MB, one simple object with several texture layers) and wait for 10 seconds No one would care about saving every now and then if 3D Coat would be a stable solution but we all know the thruth, right :P Edited April 22, 2019 by Marci Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 22, 2019 Report Share Posted April 22, 2019 I forwarding this issue to developers Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 23, 2019 Report Share Posted April 23, 2019 Compression does not lock edit process, so it packs, but you may continue to work. 1 Quote Link to comment Share on other sites More sharing options...
Member Marci Posted April 23, 2019 Author Member Report Share Posted April 23, 2019 Good point Andrew, thanks for clarifying and have a great day. Quote Link to comment Share on other sites More sharing options...
