Advanced Member animk Posted June 4, 2019 Advanced Member Report Share Posted June 4, 2019 I am trying to merge subTree (boolean or no boolean) and I get a messed up result. What did I do wrong? I am on latest version 4.8.40 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 4, 2019 Report Share Posted June 4, 2019 Is every layer switched to global space ? Quote Link to comment Share on other sites More sharing options...
Advanced Member animk Posted June 4, 2019 Author Advanced Member Report Share Posted June 4, 2019 (edited) Yes, all the layers are switched to global space. And this is in surface mode. If I use object-ify to separate the merged objects then merge them again, this issue doesn't show up. Could it be the problem of different object densities? Edited June 4, 2019 by animk Quote Link to comment Share on other sites More sharing options...
Advanced Member animk Posted June 4, 2019 Author Advanced Member Report Share Posted June 4, 2019 (edited) Okay, I found out what the issue was. The targeted layer can not be a empty layer. I had the targeted layer as a empty parent layer and that's why the merge didn't work. Edited June 5, 2019 by animk 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 5, 2019 Report Share Posted June 5, 2019 I am glad that you have found a solution ! 1 Quote Link to comment Share on other sites More sharing options...
