Advanced Member polynut Posted June 7, 2019 Advanced Member Report Share Posted June 7, 2019 (edited) Hi guy's I start using cut&clone and many errors start to show like object is not separated from original mesh or the error showing here : I have 45 GB free on my hardrive so i doubt my drive is the problem. Edited June 7, 2019 by polynut more info Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 7, 2019 Author Advanced Member Report Share Posted June 7, 2019 I am also experiencing weird behaviors with cut&clone since sometime it work the first time and sometime the cut out object is not the same dimension at all and i use orthogonal left view to do it here a gif showing what happen : Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 7, 2019 Report Share Posted June 7, 2019 Try downgrading to any other older version until this issue is resolved. Thx Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 8, 2019 Author Advanced Member Report Share Posted June 8, 2019 Carlo i know you are doing your best to help newcomers but i found the way to fix it after fiddling a few hours, here the way to solved the size problem : But the disk error still show up randomly on other tools and it is also showing up on older version so should i made another thread about the disk error alone? Quote Link to comment Share on other sites More sharing options...
