[Solved] Changing Texture Resolution Creates Seam Artifacts?
tekgecko
The seam is in a very conspicuous place, can you show a UV map (using "Drag files to attach, or choose files..)?  You may need to locate the seam in a less conspicuous place or delete your paint object so you can rebake it at 4k.
True, but even in a less conspicuous place that is a LOT of distortion. I found I had the depth channel on one of the smart materials set to 100% but with no detail. Disabling this seems to have fixed the issue.
  • Carlosan changed the title to [Solved] Changing Texture Resolution Creates Seam Artifacts?
