3D Coat Forums
tekgecko
[Solved] Changing Texture Resolution Creates Seam Artifacts?
Hi All,
Trying to paint using some smart materials I made at 2k for performance sake, then export at 4k. When doing the upscale however I am getting very strange artifacts along the UV seams I am then unable to get rid of:
https://imgur.com/a/bOG7wQI
Does anyone know why this may be?
The seam is in a very conspicuous place, can you show a UV map (using "Drag files to attach, or choose files..)?  You may need to locate the seam in a less conspicuous place or delete your paint object so you can rebake it at 4k.
True, but even in a less conspicuous place that is a LOT of distortion. I found I had the depth channel on one of the smart materials set to 100% but with no detail. Disabling this seems to have fixed the issue.
