New Member Nickfury671955 Posted June 14, 2019 New Member Report Share Posted June 14, 2019 It seems like the shortcuts for moving the curve nodes around are hard coded. (w=move, e=scale, r=rotate) Does anyone know a way to change them? Because the standard transform hotkeys I am used to from other programs are e=rotate and r=scale. Modal keys are completely ignored (perhaps because the tool makes use of them, too, but then you don't click on shift and the shortcut at the same time, so that explanation probably falls through) so I can't set up an alternate version using shift, either. Manually editing the shortcut file didn't work, either, because the hard coded keys override anything else. So basically as soon as you click e with active Curves tool, scale will get activated. Anyone have an idea? -Nick- Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 14, 2019 Report Share Posted June 14, 2019 Hi, some hotkey are editables but hard coded are not. Check inside the folder C:\Users\username\Documents\3D-CoatV48 opening the file Options_Hotkeys.xml at line 931 > <ID>SELTRANSFORM_SELGRAD</ID> you can see that shortcuts. Quote Link to comment Share on other sites More sharing options...
