Member Omni-Moulage Posted June 15, 2019 Member Report Share Posted June 15, 2019 Hello, In order to draw something very precise I would like to not use curves directly from 3Dcoat but import them from another software. (as DesignSpark Mechanical 4.0) Does is possible ? What I want: I created a vase and I want add two ropes perfectly horizontal. But My hand is shaking and the result is bad. Desastrous result Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 15, 2019 Report Share Posted June 15, 2019 Hi Using latest version 4.8.40 Curves > Activate curves editor > Load Curve (eps file format) Then pressing RMB over the curve, a popup show up letting you to select the command Attach tube or model array Hope this help Quote Link to comment Share on other sites More sharing options...
Member co3Darts Posted May 19, 2021 Member Report Share Posted May 19, 2021 Are there any other file types allowed like iges, step, dxf, ai or anything else? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 19, 2021 Report Share Posted May 19, 2021 On later Beta version 2021 yes. 1 Quote Link to comment Share on other sites More sharing options...
