[Solved] Blender export to 3dCoat error
netricsa
Hi,
I exported 2 objects from my  blender scene to 3dcoat by shift-selecting and using app link for 'per-pixel painting'.
Both the objects are already unwrapped.
But when transferred to 3dcoat, the bigger object has this noise, and upon inspecting I realized it has the materials but no UV's from my blend file..
any ideas what might be the issue here?
P.S.: I've already tried treat materials as separate textures and Import tiles as UV sets but no luck :(
Hi
Can you show please your import settings ?
  • Applink Developer
It seams that you have two uv-set for this bigger object. If you delete the empty uv-set then all works ok in 3d-coat. I will take a look if there is something that could be improved in code to avoid this issue.
